Still having overheating problem
Old Jan 30, 2007 | 12:02 AM
massivestunna's Avatar
massivestunna
Default Still having overheating problem
So, like I took out the stat, change out the rad, change out the waterpump, test the cooling system like 5 times (for headgasket problem, but none found), and purge the system like 10 damn times, and yet my car runs cool for a bit, then the needle goes to the hot zone. Now, where on the temp gauage should the fan come on? My fan doesn't cut on until the needle gets to the red zone. So, could that the problem?
Old Jan 30, 2007 | 12:23 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Still having overheating problem
Did you replace the thermostat????
Check your water temp sender for the fan itself, that could be why it's cutting on so late as well.
Ryan
Old Jan 30, 2007 | 12:47 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Sounds like a bad/backwards stat.
Old Jan 30, 2007 | 02:07 AM
massivestunna
Well, the temp sender goes to the computer and the Temp guage goes to the fan. so, should i test both of them? Also, my plug that goes in the temp sender is loose. Should it apply on there tighter? i think it would...cause it could move around when u drive the car.
Old Jan 30, 2007 | 02:56 AM
Colorado_Mustang
The electrical connection should be tight, or you will get errant readings.
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
