Electrical Issue - Help Needed!
Old Feb 13, 2007 | 04:03 AM
rikhek's Avatar
rikhek
Default Electrical Issue - Help Needed!
I needsome helpwith my 19 year old daughters 99 Mustang 4.6l . Manual transmission.I'm hoping you'll help me figure her problem out. Her's what she's got going on:
1. The right turn signals work, however, most of the time the dash/radio lights blink on and off in cadence with the blinker.
2. Left front turn signal will sometimes flash very slowly or not at all. Left rear works.
3. When she uses her brake the dash lights will sometimes all go out when the brake pedal is pushed.
4. Hazard lights (i.e., four way flashers) don't work at all.
5. Her cruise control stopped working around this same time. Not sure if it's a coincidence or related.
I would really appreciate some help. Thanks in advance.
Rick
Old Feb 13, 2007 | 09:06 AM
corvetteguy's Avatar
corvetteguy
Default RE: Electrical Issue - Help Needed!
Sounds like there is a grounding problem.
My guess is the console dash.
Has this car been exposed to flood?
Old Feb 13, 2007 | 09:31 AM
GreyStang's Avatar
GreyStang
#2 doesn't seem possible.. all corners of the turn lights are controled by the same blinker relay under the dash in the fusebox. The left front blinker can't blink "slower" than the left rear. But if you say that corner blinks intermittently, then that's probably the area of your trouble.
As for the hazards not working along with the cruise control, the common issue there is the steering column & it's wiring. One of the connectors might have been popped loose. Get a flashlight under there & look around a bit
Old Feb 13, 2007 | 02:19 PM
rikhek's Avatar
rikhek
No water exposure at all.
Rick
Old Feb 13, 2007 | 07:42 PM
mariotraci's Avatar
mariotraci
is there a aftermarket radio in it?
Old Feb 13, 2007 | 08:56 PM
rikhek's Avatar
rikhek
Stock, OEM radio. Never been touched. No work or mods to the car in well over a year. This stuff "just started " happening.
Rick
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
MXBT187
Aug 20, 2015 02:36 AM
defarmer
Aug 13, 2015 06:40 AM
89blueslug
Aug 10, 2015 07:20 AM
