quarter window conversion...
Old Feb 23, 2007 | 01:25 PM
Shelty's Avatar
Shelty
Default quarter window conversion...
hey, I've been thinking about changing the quarter windows on my '86 to the '87-93 style glass. I really like the clean look of the glass as opposed to the plastic "louvers" that the '86 had. Is there a way to do this? I know the bolts are acessed from the inside so I have to dissasemble the interior panels, I just want to know what I have to do to install it all. is there a special type of window sealer I have to use with the newer window? or will the weather stripping on the 87-83 glass be enough. any input would be great. I want to try to remove the existing windows without breaking them, as i may sell them on ebay or just hold onto them...
thanks
Old Feb 23, 2007 | 06:59 PM
GreyStang's Avatar
GreyStang
Default RE: quarter window conversion...
I think the plastic side moldings are seperate from the side glass.. no need to remove the glass just replace the plastic with the year you want(?)
Old Feb 24, 2007 | 04:34 AM
Li0nHart's Avatar
Li0nHart
You have to take your interior panels off to access to nuts on the underside...It's funny...on my 87, the holes for the original style 79-86 panels are still stamped into he steel so i could go the reverse of what you are dong if i wanted to. The beleive the glass on the newer style is larger than your galss...you will a have to swap the rubbertrim as well. I personally think your orignal style looks cooler....
oh..if you ever lock your keys inside and have to break a window...break the glass in the door it is cheaper and easier to replace than that little window on the side.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wishinsky
Sep 21, 2015 09:48 AM
