starts then stops
Old Oct 29, 2004 | 02:12 PM
Z20WHAT?'s Avatar
Z20WHAT?
Default starts then stops
Hey guys just a quick question. I have a 96 4.6 GT and it won't idle. I left work and it started up just fine, drove home fine, but a few hours later I went out to go somewhere and nothing. If I give it gas it will keep running, but once your foot is off the gas it shuts off. I am guessing in might be a vaccum leak or something, but I just want to see what you all thought. Thanks.
Old Oct 29, 2004 | 02:44 PM
roundman's Avatar
roundman
Default RE: starts then stops
clean the IAC and throttle body and see if this doesn't help things out some!
Old Oct 29, 2004 | 04:31 PM
cammedlx's Avatar
cammedlx
^^^^^^^^[sm=goodidea.gif]
Old Oct 29, 2004 | 07:53 PM
Dan04COBRA's Avatar
Dan04COBRA
IAC like Roundy said and check out your TPS sensor.
Old Oct 29, 2004 | 09:16 PM
Chopper's Avatar
Chopper
It could be the coolant temp sensor.When the engine is warm it runs fine.When it's cold the sensor tells the computer it's warm and the engine won't run untill it warms up.
Old Oct 30, 2004 | 03:58 PM
Z20WHAT?'s Avatar
Z20WHAT?
Hey thanks guys. I have been looking my my repair manual and and trying to check voltage and resistance on a few part. I will see it I can clean it and go from there. Thanks again.
Old Nov 1, 2004 | 12:22 PM
vfast's Avatar
vfast
I ♥ Acer
if that doesn't cure it change the fuel filter
StalkerGT
Sep 25, 2015 02:41 PM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
5.0 kevo
Sep 3, 2015 06:24 PM
