Converting 4 cyl to v8
Old Mar 8, 2007 | 06:35 PM
jmsp0610's Avatar
jmsp0610
Default Converting 4 cyl to v8
I have an 87 mustang coupe it has a 2.3 in it now i need to know what i need to change over to put a 5.0 or a v8 in it. Also can i use the same 5 speed tranny and drive shaft or do i need a diff one.
Old Mar 8, 2007 | 07:01 PM
Old_Smokey's Avatar
Old_Smokey
Default RE: Converting 4 cyl to v8
best thing would be find a junked 5.0 and get its Suspension, brakes, wiring, etc. I dont think there is much you can use drivetrain wise from a 4cyl into an 8cyl cause you would just break it.
Old Mar 9, 2007 | 03:09 AM
NeoTokyo's Avatar
NeoTokyo
You will need a new K-Member and front suspension and brakes as well as an 8.8" rear end, a double hump crossmember and a driveshaft. You will also need the EEC for the engine too, make sure it matches your year engine and what style trans you have.
Best of luck.
-Eric-
Old Mar 9, 2007 | 09:29 AM
Chitown racer's Avatar
Chitown racer
This link has some good info http://stangbangerz.com/modules.php?...cle&sid=40 and no you do NOT have to swap K members, unless its an 83 or earlier model.
EDIT: Just adding another informative 4 cyl to V8site http://www.fast351.com/cartech/4cyl.htm
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
