whats better? cold vs. ram
Old Oct 28, 2003 | 01:27 AM
Terry's Avatar
Terry
Default whats better? cold vs. ram
Ram air seems to be mostly popular on the trans ams because of the WS6 version but i think it's cool to see Ram air on the mustangs. I know ram air is effective because my friend bought a 98 trans am with ram air and it gives between 10-15hp more than without.
Old Nov 11, 2003 | 10:59 PM
89muscle's Avatar
89muscle
make a ram air?
Old Nov 25, 2003 | 04:33 PM
Muscles's Avatar
Muscles
Huh?
Old Feb 4, 2004 | 07:48 PM
Stl Wild's Avatar
Stl Wild
<FONT face="Verdana, Arial, Helvetica, sans-serif">http://www.classicdesignconcepts.com/catalog/itemdisplay/561.html</FONT>
Old Feb 4, 2004 | 08:02 PM
Stl Wild's Avatar
Stl Wild
<FONT face="Verdana, Arial, Helvetica, sans-serif" color=blue size=3>Definately go with ram air. If you think about it, cold air only takes air from your engine bay and makes a less restrictive and more direct flow. Ram air gives it even more direct flow, and restrics it even less.You are taking cold air from the surface of your hood (or wherever you mount it) and that air is pretty cold. Just like sticking your hand out the window, it gets cold. Ram air maybe more work, but you are getting more performance and bad *** styling</FONT>
Old Feb 4, 2004 | 10:10 PM
ZoomZoom04's Avatar
ZoomZoom04
if u buy some ducting you can make ram cold air ur self. get some air vent ducting and just run it from the inside of ur engine attached to ur existing filter make sure the pipe goes over it then just run the ducting down to the front air damn and there u go ram cold air!!
Old Feb 4, 2004 | 11:22 PM
N2OJunkie's Avatar
N2OJunkie
I ♥ Acer
Originally Posted by 88SaleenStang
is there a DIY forum or anything on how to make ur own cold air out of like pvc piping or anything as so?
</P>
</P>
tHATS RICER THINKING</P>
Old Feb 5, 2004 | 01:00 AM
95Stealth302's Avatar
95Stealth302
Anyone have problems with throttle response after putting in a CAI? Like lagging throttle and engine revs when you press the gas? What's the deal. I'm switching from my enging bay cone to Cold air this spring and don't want to incur any problems, I'm also going to 75mm MAF and 65mm TB.</P>
Old Feb 5, 2004 | 03:23 AM
gorbs88's Avatar
gorbs88
The only time ram air is effective is if you are doin 80+ miles per hr....The first half of the race and your cold air does just as much.....ram air is over rated.....the amount of air the engine consumes you have to be goin damn fast before you actually start to build pressure.,.
Old Feb 5, 2004 | 04:47 AM
Dan04COBRA's Avatar
Dan04COBRA
</P>
60MPH+, extremely effective if you are looking for that extra tenth or two. <IMG src=smileys/smiley11.gif border="0"></P>
