biggest cam in 302
ORIGINAL: Isaac
Magic? Need proof I'm running it?
ORIGINAL: ohsoquik02
how was you able to run that cam with stock pistons?
ORIGINAL: Isaac
I had a .542/.542 x cam in mine with P&P OE heads.
ORIGINAL: roundman
NO, but I would like to know what your piston to valve clearance is with what ratio rocker arms for that combination and how thick a head gasket are you using????
ORIGINAL: Isaac
ORIGINAL: Isaac
ORIGINAL: roundman
ORIGINAL: Isaac
ORIGINAL: Isaac
the x cam works with a lot of stock stangs, but most likely your in california considering cams, i would go with the E, not a bad cam, but still adds power, and as far as the clutch goes, go with king cobra all the way, its pretty stiff, but definetly is worth it, my best friend runs a 342 stroker engine with it and hasn't had a problem in a little over a year, but then again, he doesn't do a lot of stop and go driving
bradleyb
Nov 27, 2015 07:50 PM
