C-5 from 3.8 fit 5.0?
Old Mar 18, 2007 | 10:39 PM
wman24's Avatar
wman24
Default C-5 from 3.8 fit 5.0?
Will a C-5 from a 3.8 fit 5.0? It seems the bolt pattern is the same. Is the bell any deeper(front to rear) to make up for shorter block? I'm not worried about hp this is just to get a old project car mobile.
Old Mar 18, 2007 | 11:01 PM
PONY GUY's Avatar
PONY GUY
Default RE: C-5 from 3.8 fit 5.0?
yes it will same case just a bit heavier
Old Mar 18, 2007 | 11:16 PM
wman24's Avatar
wman24
What is heavier the case or interals?
Old Mar 19, 2007 | 05:00 AM
NeoTokyo's Avatar
NeoTokyo
it depends on the year too!
A 94+ model is called a T5OD which is the same damn thing except the input shaft is 3/8ths inch longer, so good luck having having it match up correctly, it wont fit right at all. And if you put a 5.0 T5 on then its shorter and you will eat pilot bearings up among other problems that may occure.
Another thing that you should be aware of is that the V6 version is weaker and wont hold up as well as the GT models.
-Eric-
Old Mar 19, 2007 | 11:21 AM
wman24's Avatar
wman24
Not a T-5 a C-5 auto from a 83gl.. It appears a C-4 is around a 1-1/2in shorter than a C-5. This is a orinal 3.8,3spd. auto(no OD)hatchback I put in strorage in 96. I have a 83 ho sitting in car and the orig trans(form 3.8) is sill in back of thegarage. Before I waste a lot of time and effort I wanted to figure if this trans would work just to get car mobile for first time in a decade.
Old Mar 19, 2007 | 06:30 PM
NeoTokyo's Avatar
NeoTokyo
[sm=oopssign.gif][sm=sorry.gif][sm=thanx.gif]
Oh it wasnt 3/8's on the T5 either it was 11/16th's
So if you ever have the need to know (Iguess) maybe I helped in some crazy 2nd dimension backwords way.... LOL
Sorry I dont know much about C-5's
A C4 or C6 then sure, but not really sure on the C5.
-Eric-
Old Mar 19, 2007 | 10:19 PM
davnsam6's Avatar
davnsam6
yes that c-5 will work from a 3.8 to an 5.0 as long as you still have the torq converter for it .it can also be converteted to a c-4 by changing out the valvebody from a c-4
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
mdg
Oct 1, 2015 07:04 AM
mrappe
Sep 26, 2015 10:16 AM
col2560
Sep 25, 2015 08:59 PM
