tearing an engine apart, first one
Old Nov 10, 2004 | 08:49 PM
BlackMage's Avatar
BlackMage
Default tearing an engine apart, first one
Yea so i started tearing apart my 94 ford explorer because the cylinder head gaskets are blown on the one side, well we found some newer heads we're putting on it and in 2 hours we have it stripped all the way down to the valve train, this si the first engine ive torn down, well with the help of my friend, and it is not tjhat hard at all, as long as you label stuff and releasing the fluids you need to, you'll be fine, and all the right tools help i'll let u know how it goes once we get everything back together
Old Nov 11, 2004 | 07:28 PM
roundman's Avatar
roundman
Default RE: tearing an engine apart, first one
Have fun!
Old Nov 11, 2004 | 11:55 PM
BlackMage's Avatar
BlackMage
OK so we got all teh way down to the cylidner heads, pull the exhaust manifolds and we are on our way to pulling the heads off and getting the new gaskets in, welllllll, we break 3 of the bolt heads off, 2 on the driver side and one on the passenger side, ok so we can deal with this, disconnect the exhaust piping from the headers and then cut the bolts out of the headers once we get the cylinder heads out, so we go under the vehicle to disconenct the piping, and our air impact gun wont even break the bolts loose, so we're a day behind what we wanted and now we probably have to cut teither the bolts or the piping, ah the fun of auto mechanics
next project after this, tearing the stang down, and getting some new rings in it, btw, wher can i find mustang piston rings? for a 4.6L 1996
Old Nov 12, 2004 | 12:33 PM
roundman's Avatar
roundman
two words for you: LIQUID WRENCH this stuff really helps break rusted nuts and bolts loose if you soak them good and let them sit awhile.
I'm sure you can get pistons and such from Summit at www.summitracing.com or www.jegs.com.
Old Nov 12, 2004 | 12:34 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
liquid wrench < pb blaster
but thats just my preference
both own you!
Old Nov 13, 2004 | 12:25 AM
BlackMage's Avatar
BlackMage
PB blaster all the wya man, we got the headers off and now we have the cylinder heads and the lower intake manifold off, so we can now send em in to check for cracks in the head
Old Nov 13, 2004 | 07:33 PM
vfast's Avatar
vfast
I ♥ Acer
mark everthing
Old Nov 14, 2004 | 02:15 AM
BlackMage's Avatar
BlackMage
yup got everything marked, no problems there
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
aleit2013
Sep 4, 2015 11:58 AM
