overheating problem
Old Mar 23, 2007 | 08:32 PM
TRIGGER1980's Avatar
TRIGGER1980
Default overheating problem
Hi All,
i have a 2005 Mustang GT, Supercharged with a procharger D1SC, running around 410 bhp..
I’m having some major problems with my heating system. After investigating further i came to find that the fans are working when they wanna work..
On the 2005 the fans have 2 settings, High speed and low speed.. When i drive normal the fans are ok (on low speed) but when i take the car on a joy ride the fans stop and the car overheats immediately.. After data logging the car several times i saw the fans from the PCM shows everything is fine when in low speed mode, but then when it changes to high speed the fans do not come on and of course the low speed fans have turned off to allow the high speed fans to take over..
Sometimes the datalogs even show the high speed fans are working but when i stop the car and check the fans are not on, causing the car to overheat in know time..
Has anyone and ideas or suggestions? i have checked the fuses and relays = Fine, i have changed the thermostat already.. The tune is correct..
Does anyone know where i should be looking to resolve this problem?
Thanks in advance for any help u can offer.
Cheers.
Mark
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
