Manual Rack
Old Nov 13, 2004 | 05:23 PM
fast83gt's Avatar
fast83gt
Default Manual Rack
How hard is it to replace the power steering with manual. I'm hoping to swap out engines before the spring. (If I finish the new one by then) I figured it would be a perfect time to change the steering.
Old Nov 13, 2004 | 08:06 PM
Obsol3te's Avatar
Obsol3te
Default RE: Manual Rack
How much harder is it to steer without power steering?
Never had a car with a manual rack
Old Nov 14, 2004 | 01:44 AM
Acer2428's Avatar
Acer2428
Site Mod
IT'S A BISH! Esp. in a manual car....
Old Nov 14, 2004 | 03:10 PM
fast83gt's Avatar
fast83gt
This was the last ford I had with Manual steering. It's not to hard to steer once you start moving. Besides my stang isn't a daily driver. It would suck as a daily driver with the suspension mods it has
[IMG]local://upfiles/7057/64326AEAC7AE42D790F4F63495C27626.jpg[/IMG]
Old Nov 15, 2004 | 10:55 PM
slo93aod's Avatar
slo93aod
Manual racks are simple to install, if you use a ford rack you'll need the iron piece that connects the rack's shaft with the steering wheel shaft (the one with 1 bolt in it).
They dont turn hard after 2 weeks you wont notice. No pump, no hoses, no leaks=good!
Old Nov 18, 2004 | 01:31 PM
Fallstar01's Avatar
Fallstar01
How much weight/belt drag can you really save by doing this? My last car didn't have power steering and it sucked for things like parallel parking or anytime you have to turn your wheel when it's not moving. This car was a basic manual 1.9L saturn that weighed next to nothing. I'd imagine that large sticky ZR tires and the extra weight of a V8 would make this even tougher.
Old Nov 18, 2004 | 11:10 PM
fast83gt's Avatar
fast83gt
Every little bit helps. Besides it's not my daily driver
Old Nov 19, 2004 | 12:09 PM
slo93aod's Avatar
slo93aod
Do it. I weighs more then you think. Then take out the smog pump, your belt would run in a perfect "v" and it gives you more room under the hood
Old Nov 19, 2004 | 08:19 PM
fast83gt's Avatar
fast83gt
The engine I'm building won't have a smog pump to remove.
The reason I have an '83 is because it is the last year exempt from emissions in MA.
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
allenmaty
Sep 24, 2015 09:17 AM
Blk Vert
Sep 9, 2015 12:16 PM
Mustangmalo
Sep 6, 2015 05:22 PM
