Gas smell
Old Mar 27, 2007 | 11:35 PM
kmobrien76's Avatar
kmobrien76
Default Gas smell
So I filled the tank and apparently over-filled it, only had the car for probably 800 miles or so...so there was gas coming out of the bottom of the car, smelled...drove it 110 miles, got to 1/4 tank, sounds like it's going through too much gas, my motorcycle gets 130 out of 3.5 gallons, 110 for 11 gallons in the Mustang, I think there's a leak, thoughts? I can smell it inside the car as well, granted it's a vert but still...
Thoughts?
Old Mar 28, 2007 | 01:00 AM
samseed101's Avatar
samseed101
Default RE: Gas smell
First clean the bottom side of the car to make sure it's clean. Then fill it properly and check again. If you are getting 10MPG, then chances are you are just running really rich and not necessarily leaking gas. Running rich would give you that gas smell and would cause bad mileage. But if you do think it'sa leak, check your injectors, rails, lines, etc.
Old Mar 28, 2007 | 09:22 AM
corvetteguy's Avatar
corvetteguy
You might also try parking on a clean concrete surface
and run the car. you might spot where the leak is
coming from. Not sure of the age of your car, but my
89 GT was leaking from the return line of the gas
line in back of the front wheel. Took me a week to
find the pinhole.
Old Mar 28, 2007 | 10:52 AM
kmobrien76's Avatar
kmobrien76
96 GT...
Come to think of it there was a spot in my garage near the front right wheel area last week, hmmmmmmmm...
Old Mar 30, 2007 | 01:23 AM
NeoTokyo's Avatar
NeoTokyo
Another place to check is the rubber gromit that goes into the gas tank from the filler neck, those things go bad in about 5 years and start dumping fuel in just 7. I have had 2 SN-95's that had the same problem. Its a part that is less than $30 bux at Kregan or Autozone but it is a royal bitch to puton.
That is another area to check, but you should track down the whole fuel system, if you saw a spot then investigate it well.
-Eric-
Old Apr 2, 2007 | 07:37 AM
kenv's Avatar
kenv
Yeah, the rubber donut that holds the filler tube in the tank has a tendency to split as they age, causing to leak from the tank when you fill it. Thats what happened on my `00GT. They had to drop the tank to install a new one.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
