replacing alternator
Old Mar 28, 2007 | 10:40 PM
sixerballa's Avatar
sixerballa
Default replacing alternator
im having trouble putting the belt back on my alternator where is the pully to adjust the tension or how do i get it back on
Old Mar 28, 2007 | 11:34 PM
sfi's Avatar
sfi
Default RE: replacing alternator
How'de you get it off. You should have a automatic belt tensioner on your set/up. It should have a square hole in it that you can put a socket wrench to(w/out socket) and pull towards you and it should losen the whole belt to you can slip it around your pullie. This is the way it works on the v8 for that year. Sorry if it's different, I can't imagine why it would be.
Old Mar 29, 2007 | 05:05 AM
sixerballa's Avatar
sixerballa
where is this square hole
Old Mar 29, 2007 | 12:18 PM
ponysnake99's Avatar
ponysnake99
directly across from the pulley, the tensioner is the pulley not attached directly to the engine, its on an arm. If you still can't find it look around your engine bay for the belt diagram
Old Mar 29, 2007 | 05:55 PM
laserred02's Avatar
laserred02
the belt tensioner for th e3.8L is on the front of the engine on the passenger side, it is down in the corner a bit, you put a 3/8" drive socket wrench in there and you can loosen the tension. it really helps to have two sets of hands so that one can loosen the tension and the other can slide the belt over.
good luck
Old Apr 2, 2007 | 07:48 AM
kenv's Avatar
kenv
Not sure about the six banger, but if its anything like the 4.6L, you might want to make a drawing of the belt routing, or take a digital pic before you remove the belt. It will save a lot of cussing later.
5.0muscle
Jan 11, 2016 01:17 PM
Golfsito
Oct 6, 2015 11:02 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
