OIL PRESSURE?
Old Mar 31, 2007 | 11:08 PM
351W THUNDER's Avatar
351W THUNDER
Default OIL PRESSURE?
351w at about 2 grand is about 60-70 oil pressure. idle at hot it around 40psi. is that high. what will go wrong if its to high??
Old Apr 1, 2007 | 01:41 AM
Li0nHart's Avatar
Li0nHart
Default RE: OIL PRESSURE?
70 seems a bit high...maybee your guage is off a bit...too high and you can start to blow seals.
http://www.carmemories.com/cgi-bin/v...erience_id=132
Old Apr 1, 2007 | 07:16 PM
Colorado_Mustang's Avatar
Colorado_Mustang
What kind of oil pump do you have? What are the clearances on the main bearings? What kind of oil are you using?
Old Apr 1, 2007 | 10:25 PM
351W THUNDER
its an oem pump.. we made the tolerances right on to the specs. and were running 15 30 shel retela.. what do u have on your mind
Old Apr 2, 2007 | 02:59 AM
Colorado_Mustang
Tight clearance + heavier oil = high pressure.
You are a bit high for stock clearance and a stock pump. You may have a bypass valve that's sticking in the pump (all pumps have 'em, high pressure pumps have a heavier spring to keep the valve closed longer).
After your break in, switch to a 5w-30 or 5w-20 synthetic(I personally recommend Amsoil for their written warranty, but Royal Purple and Mobil 1 are also very good). The thinner oil will drop the pressure somewhat. You could start with the dino versions of these weights to see where you're at to save some $$$ and do it within the break in period.
I wouldn't worry about the pressure itself, the possibility of a defective bypass valve is more of a problem. I have my bypass set at 80psi with 20w-50 synthetic racing oil for my 302 (10psi per 1k rpm as designed...plus a little margin).
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
