shifting
Old Apr 5, 2007 | 12:40 AM
moot09's Avatar
moot09
Default shifting
ok i knwo how to shift fast with out missing gears.i need to know the secret if there is one about speed shifting. i have a short throw shifter on my 97 gt im not sure what brand becae it came withmy car. but i would appreciate it if i could get some help on the subject
Old Apr 5, 2007 | 12:44 AM
GreyStang's Avatar
GreyStang
Default RE: shifting
No secrets to speed shifting.. Just shift like you do now just keep the throttle floored...
I hope your transmission is still under warranty
Old Apr 5, 2007 | 12:45 AM
moot09's Avatar
moot09
that might work cuz let of the throttle in between gears so ill give it a try. thanks
Old Apr 5, 2007 | 01:00 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Power shift is leaving the throttle wide open while shifting. This shortens the life of the drivetrain drastically. It will also slow you down in the lower gears since you have no control over your traction. This is especially important with the 1-2 shift.
Shifting fast isn't as hard on your drivetrain and will be very close, if not quicker than, power shifting.
Old Apr 5, 2007 | 11:10 AM
Chopper's Avatar
Chopper
It takes practice.You can practice without getting "exhibition of speed" tickets by shifting the transmission quickly every time you change gears.The goal would be to push in the clutch and change gears as quickly as you can without mashing the gas to the floor.Once you get to know the proper feel to the shift handle you start practicing with more and more throttle.One important thing to remember,you must have the transmission FULLY IN GEAR before you release the clutch or it most likely will pop out of gear.A clutch release while the handle is between gears will result in a grind.It might be to your advantage to see for sure that it's really an aftermarket shifter and not just a different shift handle.
Make sure the tranny is up to this kind of abuse or it 's going to mean a trip to a rebuilder for new innards.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Mustangmalo
Sep 6, 2015 05:22 PM
