NO LOW END TORQUE ON MY GT CONVERT. HELP!!!!
Old Nov 24, 2004 | 02:08 AM
askernie's Avatar
askernie
Default NO LOW END TORQUE ON MY GT CONVERT. HELP!!!!
I have a 1990 Mustang Gt Convertible...I took my friends advise and installed Mac 1 5/8 unequal length headers, underdrive pulleys, BBK X-Pipe with NO CATS, smog pump was taken off. In fender free flow air filter, Hot coil, aftermarket cap and rotor, and aftermarket cables. It still has the stock mufflers.
After installing all of this..the car has lost most of its low end torque. To back it out of the garage I have to accelerate it so it will pick up speed. If I downshift into 2nd..it gets really slow...On the highway...ITS GREAT...but this low end torque deal sucks...
I have been told everything, Install a 3:55 or 3:73 rear end to compensate...Take off the Mac 1 5/8" headers and go with 1 1/2" instead since it is a convertible and is heavier...some say...I should have never gone with the 2 1/2" X-pipe....
I DONT KNOW WHAT TO BELIEVE!!!!!!
HELP!!!
ASKERNIE
Ernie Fuentes
Old Nov 24, 2004 | 02:11 AM
Redline03GT's Avatar
Redline03GT
Default RE: NO LOW END TORQUE ON MY GT CONVERT. HELP!!!!
Get your car dyno tuned. It will cost you a bit, but theres a good chance your CPU is not reading the modifications correctly, and all that torque is waiting to be unleashed.
Old Nov 24, 2004 | 01:22 PM
roundman's Avatar
roundman
try disconnecting the negative battery cable for at least 10 minutes to clear the KAM (keep alive memory) in the ECU and then let it learn the new sensor readings and see if this doesn't help things out some. the headers and pipes are no way too big! I have the same size but equal length headers and didn't lose anything, gained instead.
Old Nov 25, 2004 | 02:14 PM
Dan04COBRA's Avatar
Dan04COBRA
Make sure there are NO leaks in your exhaust too, check them header bolts again...
Old Nov 25, 2004 | 02:37 PM
Obsol3te's Avatar
Obsol3te
Did you put the rotor on the way you took it off?
Is the fireing order correct?
And check your timing too.
Old Nov 25, 2004 | 03:16 PM
import slayer's Avatar
import slayer
ORIGINAL: Obsol3te
The rotor can only go on one way.
Are you sure the tranny is ok?
Old Nov 27, 2004 | 09:18 PM
me alot fast than u's Avatar
me alot fast than u
I ♥ Acer
just a ?....why put an x pipe and use stock mufflers all you did was choke off the exhaust......I would reset you tps, clean your electronics in your maf, check your timing and exhaust leaks..you did however do the right thing with the headers..and a good 3.90-4.10 gear will help a ton
mtgldr
Feb 3, 2024 09:00 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
LivingInThePast
Sep 16, 2015 12:20 PM
dalefrancis88
Sep 11, 2015 07:15 AM
spamedic
Sep 9, 2015 12:15 AM
