Whats wrong with my heat?
Old Nov 25, 2004 | 03:42 PM
ponyboy95's Avatar
ponyboy95
Default Whats wrong with my heat?
The other day I turned on my car and then I turned on my heat but the front defroster turned on when I put it on vent. so I turned it to floor and It still only blew thru the front defroster. I've tried it on every setting EVEN AIR and the only airflow goes thru the front defroster!? what the heck is that? Has anyone ever heard of that or have any ideas as to how to fix it?
Old Nov 25, 2004 | 04:28 PM
11seccobra03's Avatar
11seccobra03
Default RE: Whats wrong with my heat?
See if the switch unhooked at the defroster position
Old Nov 25, 2004 | 10:23 PM
luckythirteen13's Avatar
luckythirteen13
vacuum leak. thats why the door that controlls which vent the air comes out of isnt moving
Old Nov 25, 2004 | 11:23 PM
roundman's Avatar
roundman
yep, it's a vacuum leakage problem for sure. start under the hood and look for the vacuum line that goes into the firewall on the side near the heater hoses and makes sure it is not loose or cracked. if this doesn't fix it, then you need to get behind the control switch panel and check back there to see if it has come loose from the rotary switch.
Old Nov 26, 2004 | 02:11 AM
fullthrottle's Avatar
fullthrottle
Ditto
Old Nov 26, 2004 | 09:44 PM
ponyboy95's Avatar
ponyboy95
thanks! I'll try that!
PaulH2
20
Jan 31, 2016 09:48 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
marc954
Sep 29, 2015 11:18 AM
