z-303 cam
Old Nov 28, 2004 | 03:08 AM
BoostedStallion13's Avatar
BoostedStallion13
Default z-303 cam
Ive been looking around lately for a cam for a mildy modified motor. The Z-303 cam across and I was wondering what is everyone elses opinions on it. Pros, cons.. Would i have to notch my pistons with this cam. I hear a lot of good things about the x-303 cam so I would think it would be the same with the Z since the specs are really close between the two.
Derek
Old Nov 28, 2004 | 03:19 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: z-303 cam
whats the specs on the Z?
Old Nov 28, 2004 | 03:23 AM
BoostedStallion13
duration- 290/290
lift- .552/.552
lobe seperation- 107 degrees
duration at 050 inch lift- 228/228
Old Nov 28, 2004 | 03:25 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
wow thats a BIG cam... with alot of overlap.... I doubt seriously that will clear the stock pistons without some work
Old Nov 28, 2004 | 07:22 AM
cammedlx's Avatar
cammedlx
yep i would just go with the e cam i think im going to go with a custom grind from comp
Old Nov 28, 2004 | 09:32 AM
FoxGT's Avatar
FoxGT
dominates my x303. How much are they?
Old Nov 28, 2004 | 02:05 PM
Birdieman4's Avatar
Birdieman4
It won't clear the stock pistons.
Old Nov 28, 2004 | 05:06 PM
BoostedStallion13
Isaac...What mods do you have in your mustang and how do you like you x-cam? If it clears stock pistons then that would be a better choice. I would probably then go with an x-cam and maybe 1.7 roller rockers.
Old Nov 30, 2004 | 06:32 AM
FoxGT's Avatar
FoxGT
I'm not sure if 1.7 with an xcam is a good idea with a stock 302. I love my x303 & it even went on without modifying the 302 to make it fit.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
