torque convertor
Old Apr 12, 2007 | 11:55 PM
351W THUNDER's Avatar
351W THUNDER
Default torque convertor
i have a stock torque convertor in a suped up 351w.. if i change it and put a better one in what will happen and wat better performance will i gain from it... idle is around 800 rpm and wen i put it in drive it goes down to about 650.. any less and it stals .. any good??? what should i put in it.. thanks guys
Old Apr 13, 2007 | 12:41 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: torque convertor
A little more stall will put less strain on your engine at idle. It will also allow your engine to reach higher RPM's before locking up, giving you a better launch.
Just make sure any stall speed you pick is lower than your typical cruise RPM. If it isn't, you can burn up your tranny with the excess slipping of the torque converter.
mtgldr
Feb 3, 2024 09:00 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
LivingInThePast
Sep 16, 2015 12:20 PM
spamedic
Sep 9, 2015 12:15 AM
