i had the same problem . a little wd 40 on the lower spring seats and the noise went away. also ford has a tsb or ssm #17100 to replace the lower control arms for a similar condition.
ford also has a tsb to replace the brackets (hollow tubes ) that go through the rack and pinion. i replaced mine but the springs were the problem . good luck !
