Damn stereo...
Old Apr 20, 2007 | 04:00 PM
JonnGT's Avatar
JonnGT
Default Damn stereo...
Yesterday my dad and I pulled out the stock decks due to the CD player no longer reading CDs.
We went to Best Buy, bought an installation kit to fill the gap of where the old CD player was and boguht a harness for the new deck.
After some fiddling around and trying to disconnect the speaker cable from its set harness on the right side of the console (behind the old deck) and putting it back in, my dad finally figured out he had the wrong harness and the AMP wasn't being used, so we exchanged the harness for the correct one and proceeded to install it again...
Well now we have an issue, and I hope it isn't an expensive one...
We no longer recieve any sound from the speakers, unless we re attach the stock deck and turn it all the way up.
But even then it only plays as if the volume was 2/10 bars instead of all the way up.
Umm, I hope that enough info but just incase it matters,
I have a:
1996 Ford Mustang GT
4.6L V8
Mach 460 System
Old Apr 20, 2007 | 06:32 PM
jerrylee01's Avatar
jerrylee01
Default RE: Damn stereo...
sounds like maybe since had wrong plug on it 1rst time might of shorted out the factory amp . i would jus try too find your speaker wires in your harness and do away with the amp . hook it all up direct .
Old Apr 21, 2007 | 08:02 PM
JonnGT's Avatar
JonnGT
gah damn it, was hoping it wouldn't be that bad...
alright well is there anyway to diagnose it without giving ford like $120 juss to look?
Old Apr 22, 2007 | 01:42 AM
TwotoneVert's Avatar
TwotoneVert
Yes, go back to Best Buy, go in the back, and ask to speak to a installation tech. They will explain how to install your deck that you just purchased. On some models, and I am not familiar with yours. But, the factory amp will not work with an aftermarket deck. You have to ditch it. Its not a big deal, just a pain to get to sometimes. Talk to the guys who put that stuff in, they can help you in the right direction and get you what you need. Like I said, I am not familiar with your model of stang, but on mine, I had to purchase another plug, wire in the speakers that plug, and the other one that came with the install kit also connected to the aftermarket deck.
Old Apr 22, 2007 | 03:22 AM
aftlcc's Avatar
aftlcc
A LOT of after-market cd players don't support factory amps and need to be by-passes. Thats what I had to do in my Ranger...
Old Apr 22, 2007 | 05:50 PM
dastangman's Avatar
dastangman
perhaps you should ask this is the audio/visual section, you'll get more responses
Old Apr 22, 2007 | 09:20 PM
JonnGT's Avatar
JonnGT
ok awesomer gonna check all that stuff out and if it doesn't work I'll move to the audio/visual section.
thanks a bunch for the help guys
Old Jan 13, 2013 | 09:52 PM
dukeboys75's Avatar
dukeboys75
How many watts is the stock amp in a 96 mustang gt?
drfister
May 3, 2018 10:38 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
mungodrums
Sep 28, 2015 05:45 AM
MonsterBilly
Sep 20, 2015 06:56 AM
