idle problem!
Old Apr 21, 2007 | 08:37 PM
mik98's Avatar
mik98
Default idle problem!
Hi. I have 98 Stang GT, standard trans. Recently I've noticed(when engine is in N) after I give some gas, RPMs go up and then drop down fast to less then 500 and the engine almost stalls, and then goes back up to 800- 900 RPMs.Do you know what could be the problem? Thanks a lot.
Old Apr 21, 2007 | 09:45 PM
67mustang302's Avatar
67mustang302
Default RE: idle problem!
Is the check engine light on?
Old Apr 21, 2007 | 10:45 PM
mik98's Avatar
mik98
No its not "ON". and I noticed that it happens only when the engine is warm. In the morning when I start it the first time everything is ok.
Thanks for replying.
Old Apr 21, 2007 | 11:31 PM
meanfox's Avatar
meanfox
You should probably start by cleaning out your iac valve really well and also cleaning your maf sensor.. Also you may have a small intake leak coming from a leaking intake gasket.. When the car is idleing at operating temp spray some brake or carb clean all around the intake. If the engine stalls down at any point then you found a leak.
Old Apr 22, 2007 | 12:14 AM
67mustang302
Yep, cleaning iac, maf etc is a very good idea, as well as the brake cleaner trick. If that doesn't work, look up in a manual what the resistance/voltage of some sensors are and test them, tps, ect, o2 etc. A bad voltage reading ofless than avolt can throw off the tuning like that
Old Apr 22, 2007 | 01:22 AM
mik98's Avatar
mik98
Thanks a lot for advice guys. I will try that.
Old Apr 22, 2007 | 06:06 AM
NeoTokyo's Avatar
NeoTokyo
+1 on Cleaning the IAC
Before the engine swap in my wifes 96' it had idle problems and even died in traffic and didnt want to start again after that.
That happened to be the first thing that I addressed and I cleaned it with carb cleaner and put it back on, no problems ever since!
-Eric-
Old Apr 22, 2007 | 06:18 AM
Sxynerd's Avatar
Sxynerd
YOur decay is off.... Could be your IAC, TPS, or a clogged Cat, vacum leak.
Old Apr 22, 2007 | 02:53 PM
LilRedHoss's Avatar
LilRedHoss
I'd look for an intake leak too.
When the engine is cold everything is sealed tight.
When it warms up, things expand and may warp out of line a little.
Try checking the torque on your intake bolts 1st.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
