battery relocation problem!!! question!!
Old Apr 28, 2007 | 05:59 PM
mach5racing4's Avatar
mach5racing4
Default battery relocation problem!!! question!!
i have a 95 5.0 gt a with a optima red top batteryand I just movedthe battery to the trunk with a summit racing relocation kit, i connected the new power cable to the 2 cables up front and ran a ground under the car and bolted it to a clean spot on the frame, now when i try to start the car it wont start, all the lights and everything come on but it wont fire up. even when jumped it wont start but if i connect ajumper cable to the exhaust and to the neg. side it will start. i cant figure out why it wont work. did i forget to do something? hasanyone ran into this before? thanks
Old Apr 28, 2007 | 06:17 PM
hellion_79's Avatar
hellion_79
Default RE: battery relocation problem!!! question!!
Are you sure its a clean spot?
Old Apr 28, 2007 | 06:44 PM
mach5racing4
yeah i fount a bolt threaded into the frame and i bought a brand new bolt and wire wheeled the area, andits a 12mm bolt
Old Apr 28, 2007 | 07:03 PM
hellion_79's Avatar
hellion_79
Did you mess with your starter wires or starter solenoid wires?
Old Apr 28, 2007 | 07:04 PM
hellion_79's Avatar
hellion_79
oh and how much did that relocation kit cost you??
Old Apr 28, 2007 | 08:33 PM
mach5racing4
i figured it out, i am retarted. i forgot to re-ground the engine when i took the battery terminal out. its all set. the kit was $70 from summit, thanks
Shifty Magoo
Aug 25, 2015 03:08 PM
Soldier GT
12
Aug 20, 2015 09:42 AM
jjwinel78
Aug 17, 2015 03:34 PM
drumhedd2005
Aug 13, 2015 09:59 AM
UINZWAY
S197 Shelby Section
Aug 5, 2015 10:34 PM
