Turn Signal Question
Old May 23, 2007 | 06:48 PM
Bdog30's Avatar
Bdog30
Default Turn Signal Question
I have a 92 5.0 Mustang and have an issue with my turn signals. When I turn the left blinker on nothing happens inside the car. SometimesI can hear what seems to be aclicking but yet nothing is still happening.On the outside the light comes on but does not blink in front or back. My right turn signal works but is really slow. Looked at the manual I have and changed the signal flasher and that was not the issue as the problem persists. Any ideas are helpfull.
Old May 23, 2007 | 10:19 PM
corvetteguy's Avatar
corvetteguy
Default RE: Turn Signal Question
Did you change the signal flasher
Or the hazzard flasher?
Old May 23, 2007 | 11:30 PM
89 fox's Avatar
89 fox
ORIGINAL: corvetteguy
check that...and also check the wires going to your key cylinder in the steering column...that is where mine is messing up...still gotta chase down the problem...
Old May 24, 2007 | 03:05 AM
Bdog30's Avatar
Bdog30
Well I got the turn signals to work on the outside both ways. The Haynes manual I had said the turn signal flasher was in the fuse box but on this car its up above the glove box. I changed that and the signals work on the outside but now on the inside the left one still does not work even when hazards on. I am sure getting behind that panel is going to be fun to change a bulb if thats the problem. Thanks for the replies and hope you can help with the next step.
Tivo304
Aug 28, 2023 12:19 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
