LEDs
Old May 29, 2007 | 12:36 AM
Double's Avatar
Double
Default LEDs
I just bought http://www.americanmuscle.com/9904-led-angleeye-projectors-black.html and need some help splicing the wires so that the LEDs work properly because I really don't want to blow my lights. I have the lights set up, easy stuff, but just would like some help with the LED part. So how do I wire the lights together?
Also, is the backlights just as easy as the front? All I need to do is take out the bolts inside the trunk to get to them right?
Old May 29, 2007 | 08:41 AM
corvetteguy's Avatar
corvetteguy
Default RE: LEDs
At $289 I would expect tat the kit comes
with detailed instructions.
LEDs ar polarity sensitive, so hooking it
up reversed will cause it to not work.
It is also possible that damage can be done to any
regulator if reversed.
Old May 29, 2007 | 03:52 PM
Double's Avatar
Double
Default RE: LEDs
yea, I was fairly dissappointed with not recieving instructions for hooking them up correctly, and seeing how they did cost a fair amount of $$ I really don't want to bust them. I was wondering if anyone had these or something similar that could shed some light for me.
Old May 29, 2007 | 08:39 PM
corvetteguy
Default RE: LEDs
I know you can hook a 10,000 ohm resistor
in series with a 12 volt battery and connect it
to the leds, In the right polarity they will light a little.
In the wrong way you won't burn them out.
Diode Dynamics
28
May 26, 2022 12:02 PM
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
accarter
Sep 21, 2015 11:56 PM
Colin Ringle
Sep 15, 2015 09:27 PM
