brown radiator water
Old Jun 8, 2007 | 04:43 PM
ctgreddy's Avatar
ctgreddy
Default RE: brown radiator water
my coolant was like that too. i drained all the brown crap out, then filled it with just water. ran it to normal temp and drained the water out and then just put in the 50/50 mix. it worked fine and my coolant is the normal green color. : )
Old Jun 9, 2007 | 01:54 AM
robs87fox's Avatar
robs87fox
good lookin out guys, I'm going to replace the rad, and the t-stat. Do you guys have any paticular rad that's better that oem. Thanks.
Old Jun 9, 2007 | 02:54 AM
ctgreddy's Avatar
ctgreddy
i know around here the becool radiators sell really good. im not sure if they make one for the mustang but im sure they would. if not you could always try the ford racing radiator that i saw from summit.
Old Jun 11, 2007 | 07:45 PM
cottoncandymustang's Avatar
cottoncandymustang
Brown radiator water is a good indication of a blown head gasket to so be very careful with that
Old Jun 11, 2007 | 08:23 PM
67Sally's Avatar
67Sally
Check out Summit Racing for your radiator. They have BeCool like CT mentioned and that's a really good brand but there are a lot of other options as well.
Old Jun 12, 2007 | 04:40 AM
robs87fox's Avatar
robs87fox
thanks everyone
Old Jun 12, 2007 | 06:29 AM
Blckstng93's Avatar
Blckstng93
Im using your basic 3 row rad and a 180 stat. No problems here. Gauge reads a bit below 1/2 at all times.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
flash_xx
Oct 16, 2015 07:23 AM
b8checker
Oct 8, 2015 12:55 PM
