Caught in the middle!
Old Jun 7, 2007 | 12:29 PM
MustangSally99's Avatar
MustangSally99
Default Caught in the middle!
Cheese and rice!!! The Ford dealer who recently worked on my '99 GT said there was less than 20 milliamp draw on the electrical system (after replacing the amp). The local mechanic (who also races at the same track as me for 20 years) says there is 187 milliamp draw. I call the Ford dealer, and he insists the test was correct, and this other mechanic doesn't know what he's doing, maybe reading on the wrong scale.
Ford Guy says 187 milliamps would drain the battery overnight. I haven't had any problems letting her sit for a few days and still starting.
Local Mechanic says he knows what he's doing, and there IS a large draw on the battery. He worked on this car a few years ago, and we didn't trace the draw then, I simply disconnected the battery cable when I wasn't driving her.
Ford Guy says the battery cables (negative in particular) are severely corroded from resistance, and that the alternator could be the cause, since the connection there has burned the plastic and the corrosion is worst at the alternator.
Local Mechanic says there isn't any obvious corrosion, and he tested the cables and found no resistance. (He replaced the wires a few years ago, right after I replaced the alternator.)
*GRRRRRR*
So I asked Local Mechanic to spend half an hour and test the big stuff, like the alternator, to see if they can find the draw. If he can't locate the parasitic drain, what then????
I'm going crazy!!! I just want this car to be mechanically sound when I sell it, but I don't want to dump a ton of money in her.
Old Jun 7, 2007 | 06:52 PM
tncruiser's Avatar
tncruiser
Default RE: Caught in the middle!
how long does it sit before the battery goes dead?
Old Jun 8, 2007 | 01:25 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Checking the drain is about the easiest thing you can do. Insert ammeter between negative battery post and its cable (disconnected cable, of course).
Then, remove fuses one by one until the current draw goes down. You found the problem.
Old Jun 8, 2007 | 11:44 AM
MustangSally99
Last time the battery went dead was when it was at the Ford dealer two weeks ago, and they let it sit for 4 days...and it was dead.
I asked Local Mechanic to see if he could find the culprit, and he said its coming from the amplifier fuse, which also runs the radio, CD player and just about every light inside the car. I think he said he checked the 'master fuse', so I guess that means there are individual fuses for each of these functions. He said it could take hours to trace it, at $90/hour.
A meter costs $10, and it might take me a whole afternoon. Is this something I could do myself? I've been under the hood since I was 16...many many moons ago, so I think I could learn how to do it.
Thanks for the responses, guys!
[IMG]local://upfiles/9569/CE66E9DB3FA645FF889C1DDD2DAEF009.jpg[/IMG]
Old Jun 11, 2007 | 12:40 PM
MustangSally99
So it's the "F" fuse, position is I/P (don't know what that means) and circuits protected are Instrument Cluster and PCM (Power control module?) not sure what that is either.
The question remains, what fuses under the dash are contected to this fuse?
Old Jun 14, 2007 | 01:20 PM
MustangSally99
Talkin' to myself now...
I'm testing the electrical drain by letting the car sit for a few days and using the instrument cluster diagnostics.
Saturday was the last time I drove her. No problems.
Tuesday I checked the battery voltage by using the gage on the dash and the diagnostics. The dash gage needle was right in the middle, and the diagnositcs gave me a code of 148.
Thursday I checked again...gage needle was in the same place, but the code is 145 now.
So I definately have a drain. It may take another 7-10 days to really know how much and how fast.
I'll keep this thread going in the hopes that I come to some conclusion, andhopefully will help someone else with a similar problem
Old Jun 18, 2007 | 11:56 AM
MustangSally99
So here are the numbers from the instrument cluster diagnostics over 7 days:
Tuesday 148
Thursday 145
Friday 144
Saturday 147
Drove her on Saturday.
Sunday 155
My conclusion: there is no significant parasitic draw on this car. The high reading the Local Mechanic got must have been when the computer 'woke up' and was checking stuff. And maybe if she sat for 4-8 weeks there may be a problem starting, but I don't consider that to be a major concern.
Problem solved
Old Jun 18, 2007 | 12:07 PM
Gary H's Avatar
Gary H
Have you checked things like the trunk light, underhood light and cig lighter to see if they are staying on?
jwog666
Dec 27, 2021 08:09 PM
GPR
Dec 16, 2015 12:21 PM
TCStangerv6
Oct 11, 2015 05:57 PM
69Volunteer
Sep 30, 2015 10:39 AM
movielover40
Sep 15, 2015 10:37 AM
