E-brake is failing!!!!
Old Jun 21, 2007 | 05:42 AM
Dan9687's Avatar
Dan9687
Default E-brake is failing!!!!
I have a 99' v6 stang which I have noticed recently the E-brake is failing. Today I parked it on a slight incline with the car not in gear and it would very very slowly creep backwards while I was still in it. I have noticed also that if I look directly down to where the E-brake actually is, the metal where a screw is supposed to be holding the base down I assume, is...well....the screw ripped all the way through the metal. It looks as if it was pulled up on extremely hard alot thus causing it to rip through but I never do that so???
Anyway.....How much to fix this whole problem? Thanks.
Old Jun 21, 2007 | 09:25 AM
GreyStang's Avatar
GreyStang
Default RE: E-brake is failing!!!!
Not sure how much the parts would cost,, are you doing your own labor?
Personally I never trust the e-brake alone in holding my car parked on a hill, or hell even on a flat parking space I always leave it in gear.
jwog666
Dec 27, 2021 08:09 PM
GLOCKer
Sep 28, 2015 07:36 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mltdwn12
Sep 23, 2015 08:54 AM
TfcCDR
Sep 14, 2015 12:08 PM
