funny noise...help =s
Old Jul 2, 2007 | 11:53 PM
suikoden212's Avatar
suikoden212
Default funny noise...help =s
ok i was driving home one night i wasnt speeding or doing anything out of the ordinary. when i pulled up on my street and turned off the stero all the sudden i
start hearing this funny noise coming from what seems like my front right tire.
it sound like a squeaky loose bolt or something and to go more into detail about the noise its like when the bottom of your shoes when there wet and you walk on tile or something.
at first i just thought it was my breaks checked it wasnt that so then i checked my bolts there tight no way in h*ll that tires comin off so i just wanted a little insight anything will be helpfull.
Old Jul 3, 2007 | 12:03 AM
blackstallion666's Avatar
blackstallion666
Default RE: funny noise...help =s
does it go away when the brakes are applied.
is it over bumps or only on smooth road.
does it get faster with speed.
also if you push on the suspension when you have it parked and make it bounce does it do it.
sounds like like posibly a dry bushing creeking up front. or possibly sway bar links
Old Jul 3, 2007 | 12:12 AM
suikoden212
thank you ill check tommorow morning and nah i havent noticed anything diffrent from when i bought it.
Old Jul 3, 2007 | 12:14 AM
suikoden212
the suspension bounces like normal it does it on bumps and smooth road and no it stays the same even when i go faster
Old Jul 3, 2007 | 09:06 AM
351W THUNDER's Avatar
351W THUNDER
if ur engine heats up does it go away? b/c my friends stang sounded like that and it was the fly wheel hitting the dust sheild on the bottom of the tranning
Old Jul 3, 2007 | 04:29 PM
Blckstng93's Avatar
Blckstng93
Could be a ball joint. When they start to go bad they sound like a squeaky matress. When it starts doing it, stop and turn the wheel back and forth. If it squeaks you found the problem.
Old Jul 3, 2007 | 05:12 PM
mustanglp87's Avatar
mustanglp87
if its a ball joint, will it squeak on bumps AND turns? im having a really bad squeaky mattress syndrome im planning on fixing soon and itd help a lot to pinpoint the problem.
Old Jul 4, 2007 | 10:56 AM
suikoden212
ok if its the ball an joint is it ok to drive like say 16 miles so i can get home or not
drfister
May 3, 2018 10:38 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
