PLEASE HELP WITH MISS
Old Jul 4, 2007 | 01:08 PM
SpitnCobra's Avatar
SpitnCobra
Default PLEASE HELP WITH MISS
Ok here the problem on my 93 GT (stock) when i start the car & drive about 8 miles or so it drives just fine, after that it starts acting like its' missfiring but more like a dead miss, the RPM needle be bumping really fast 1 or 2 seconds apart.
A little more into detail New wires, plugs (Autolite), rotor, cap, ignition module, coil, and temp sensor i added a temp sensor cause my needle was showing high & i also put a new water pump on. I put the car on a friends computer & it said left lean bank is going bad CODE: 91 or 92 but that was a 02 sensor going bad so i changed that, now it's telling me tps i think the only reason it says to check the tps cause we got the car set @ 12 degr..
just trying to find out what changes from when the car is running cold to when it reaches operation temp...
[IMG]local://upfiles/70686/46760F209AF342FCBC1D28A1041CB38D.jpg[/IMG]
[IMG]local://upfiles/70686/246C4429A9EE4F7FB86467F6B491F2F5.jpg[/IMG]
[IMG]local://upfiles/70686/54226C161E354F05AED6646238B5F617.jpg[/IMG]
[IMG]local://upfiles/70686/177618A338E8492C9237AA6AAFE5ED13.jpg[/IMG]
Old Jul 4, 2007 | 03:21 PM
Chopper's Avatar
Chopper
Default RE: PLEASE HELP WITH MISS
Try pulling injector wires to see if one of them might be clogged or just worn out.When you get to the one that changes the RPM the least you've found a likely culprit.Swap this injector to a good cylinder and see if the miss folows.If it does,clean or replace that injector.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
