upper control arms
Old Jan 14, 2005 | 11:26 PM
luckythirteen13's Avatar
luckythirteen13
Default upper control arms
ive got a couple days off next week and i was hoping to install my upper arms and subframes. i was wondering if for some reason im attacked by killer bees, have a heart attack or get abducted by aliens in the middle of the job and only get one done, will it be ok to drive around with one new arm and one old. the new is supposed to be a direct bolt in replacement. the only difference will be that the new arms will have polyurathan bushings.
^^^^^^^^ can you tell ive had a lot of sugar today
Old Jan 14, 2005 | 11:54 PM
mysticsvtcobra96's Avatar
mysticsvtcobra96
Default RE: upper control arms
im sure it would be fine..but i wouldnt drive it around for too long
Old Jan 15, 2005 | 10:41 AM
vfast's Avatar
vfast
I ♥ Acer
take one day do the subframes..next day do the arms.....but it should be ok with 1 a-arm
Old Jan 15, 2005 | 10:57 AM
Mustangous's Avatar
Mustangous
The next time you buy new sneakers just put one new one on for a day or two then later on wear both.....If you have the car all jacked up and positioned right and tools out, make sure you leave yourself some time to do both. The longest part of a job is usually jacking up the car and getting all your tools out that you need.
You do them the same time anyway. you unbolt your shocks, and lower the rear and take out your springs so you get some free movement in the rear then you unbolt the uppers off the rear and raise/lower/manuver the rear to get the bolts out and lower the rear all the way down. Then you'll have more acess to get them to get them off the frame...do them the same time. then reverse the process to get them on. goodluck!!
Old Jan 15, 2005 | 11:56 AM
vfast's Avatar
vfast
I ♥ Acer
kids are great to fetch stuff
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
