Mechanical issue
Old Jul 11, 2007 | 05:52 AM
DG88's Avatar
DG88
Default Mechanical issue
Hey fellas my car makes a whining noise when i turn the key i think thats the starter thats not catchinng the flywheel. However at times it makes this loud noise when it does catch the flywheel as if it was grinding metal to metal. I know its not the engine because when I push start it it turns right on effortlessly.Its a 88 GT 5 spd. Any suggestions toughts or ideas.
Please help
Old Jul 11, 2007 | 07:22 AM
Stu's Avatar
Stu
Default RE: Mechanical issue
Your problem is in the starter.
The drive gear is not contacting the flywheel.
Get it repaired quickly because if it keeps grinding you will need a new flywheel ring gear which means removing the transmission.
Old Jul 11, 2007 | 11:12 AM
GreyStang's Avatar
GreyStang
Your flywheel might already be missing some teeth [:@] crawl under the car & you should be able to see if that's the problem
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
MusicCity615
Sep 12, 2015 07:05 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
zanemoseley
Sep 6, 2015 12:58 PM
