12V ignition wire!
Old Jul 15, 2007 | 07:17 AM
red9535's Avatar
red9535
Default 12V ignition wire!
In the fuse box under the hood, I assume one of the wires coming up into it is for the 12V ignition. What color is it? I need to tap into it and wire up my fuel pump and ignition box.
Old Jul 15, 2007 | 07:32 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: 12V ignition wire!
Generaly they are red. Get a test light and start probing.
Old Jul 18, 2007 | 11:58 PM
red9535's Avatar
red9535
Seriously, nobody knows which wire is the ignition wire under the power distribution center???
Old Jul 19, 2007 | 12:25 AM
skylark494's Avatar
skylark494
What year mustang? Look for a red/light green wire. That is what it is going into the ign switch. It could change from there, just double check with a meter. DO NOT USE A TEST LIGHT.The test light is generally a low resistance to ground that could short the ECU or BCM.
Old Jul 19, 2007 | 08:15 AM
red9535's Avatar
red9535
It's a 95
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
