ok 429 swap
Old Jan 18, 2005 | 09:56 PM
smoht's Avatar
smoht
Default ok 429 swap
Alright, I've had one question answered here, so lets see if I can get some more answers that I need. I'm doing the swap in a 96 stang. I'm using a 95 k member. Now I know a C6 will work, but would a AOD? How about the driveshaft, would I need to get it shortend up? Anyhelp would be great.[:-]
Old Jan 18, 2005 | 11:58 PM
uedlose's Avatar
uedlose
Default RE: ok 429 swap
not real sure on the AOD but the E4OD will that is the trans they used in the pick/vans with OD and big blocks
Old Jan 19, 2005 | 12:30 AM
smoht's Avatar
smoht
ford made some AOD's to work with the big blocks. I'm more in the info of like bell houseing width's and how tall they are, if they'd clear the tranny tunnel. Thanks for the info though.
Old Jan 20, 2005 | 01:44 PM
roundman's Avatar
roundman
contact the guys at www.lentechautomatics.com and see what they say about this swap. they pioneered the built up AOD tranny and know all there is to know about them. don't think a stock AOD would hold up to the higher torque of a 429, but if anyone could build one that would, Lentech could I'm sure as they make racing versions for upwards of 800 HP.
Old Jan 21, 2005 | 08:15 PM
vfast's Avatar
vfast
I ♥ Acer
if this car will see a hugh amt of racing time...I would use a chevy power glide using a plate....spring will have to be replaced as some fab to the engine mounts...you will also need a manual rack.I would set that heavy *** engine back as far as you can....I would use a ground pounder cradle
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
