Speedo broke? help plz
Old 07-22-2007, 01:45 PM
bikeboy587
bikeboy587's Avatar
Default Speedo broke? help plz
I was drivin the other day and my speedometer just dropped from 60-0 and stopped working out of no where. Then I through a Check Engine light that was P 0500 - Vehicle speed sense malfunction. I thought I just broke a speedo gear or the cable but then a through that code. Since my car is a 96 I have the manual odometer adn speedo so I didn't think it was a conputer problem. Idk if i'm throwing that code just bec my car sees that my speedo ain't working or if I did have a sense fail. What do i need to fix??[/align]Thanks[/align]
bikeboy587 is offline
Old 07-22-2007, 10:35 PM
redneck racer
redneck racer's Avatar
Default RE: Speedo broke? help plz
cable might have come loose, just take the panel off and push it back on... thats thats not it then i have no idea
redneck racer is offline
Old 07-22-2007, 11:06 PM
Colorado_Mustang
Colorado_Mustang's Avatar
Pull the sender out of the tranny and turn it over with a drill. Have a buddy watch the speedo. If it doesn't move, then you need to pull the cluster and remove the cable. If it is broke, the bottom piece may come out through the bottom, depending on the design. You shouldn't have to replace the outer housing.
Colorado_Mustang is offline
Old 07-23-2007, 06:02 PM
bikeboy587
bikeboy587's Avatar
thanks i will start off in that direction![/align]
CMcNam
10-30-2022 11:40 PM
stangin1996gt
09-21-2015 11:01 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Speedo broke? help plz
