advice needed
Old Jul 29, 2007 | 09:54 AM
uedlose's Avatar
uedlose
Default RE: advice needed
Mid 11s to Mid 10s till you get it all worked out then it should run low 10s or even some High 9s with everything right. Just my guess.
Old Sep 5, 2007 | 07:08 PM
mitmaks's Avatar
mitmaks
ORIGINAL: uedlose
OK, the rails are upgrade but what about the lines from the tank to the rails. injector swap is not that hard I would be looking into some 60s Delphi make nice stuff. A tuner for this thing would help a lot if you start moving up much more with the injectors. if you still got the stock fuel line you are gone to need to replace them with big stuff.you dont want to get that thing lean.
would 95lb injectors work fine?
bryan616fl
Jan 25, 2019 09:07 PM
cedarmn
Aug 28, 2015 09:51 PM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
defarmer
Aug 13, 2015 06:40 AM
