Carburator issues
Old Aug 3, 2007 | 12:52 PM
mustangmanic69's Avatar
mustangmanic69
Default Carburator issues
I Have a 67 mustang coupe that I have been restoring for the past 2 years. I recently swapped in a motor that I pulled out of an 81 truck. It is a 302 unlike the original 289. I went ahead and beefed up the cam using my dialing wheel and dressed up the motor. to top it off I installed an edelbrock performer intake and a holley 650 carb. When I jump on the car and the secondaries open it sounds like its leaning out in top end and it pops. I have checked the timing and the fuel mixture and I still can't find the issue. Anyone have any ideas?
Old Aug 3, 2007 | 01:07 PM
67mustang302's Avatar
67mustang302
Default RE: Carburator issues
Well, first that 650 is prolly way too big for that engine, which is basically stock. Second, does it stumble or bog when you open it up, or just seem like it has a flat spot at high rpm? And does it pop through the intake manifold and only when you first open the throttle? Also did you change the cam, or change the cam timing?
Old Aug 3, 2007 | 01:28 PM
mustangmanic69
when you open it up after you take off. take off on the primarys it runs fine and when you go straight to the secondaries it makes a loud pop and tries to die. the cam timing has been changed slightly but it has been adjusted with a timing light.
Old Aug 3, 2007 | 04:51 PM
67mustang302
You're not gonna adjust your cam timing with a light, your ignition timing, yes, your cam timing, no. Is it a mechanical or vacuum secondary carb
Old Aug 3, 2007 | 05:02 PM
mustangmanic69
vaccum secondary. I dont wanna deal with a mechanical. car pulls incredible vacuum so im just unsure on why its leaning out.
Old Aug 3, 2007 | 05:18 PM
67mustang302
What's your vacuum at idle, what power valve and secondary spring does the carb have, what's the squirter size and what pump cam?
Old Aug 4, 2007 | 01:50 PM
Colorado_Mustang's Avatar
Colorado_Mustang
You'll have to adjust how the vacuum secondary is coming on. There is a spring kit you can by to try and dial it in. Have fun. That's the reason I run mechanicals...
Old Aug 4, 2007 | 09:42 PM
67mustang302
Yeah, but you gotta tune the accelerator pump for the secondaries with a mechanical. 6 and one half dozen or the other as they say
Old Aug 5, 2007 | 11:48 AM
Colorado_Mustang
Accel. pump is infinitely adjustable. There are 5 springs for the vacuum secondaries. Especially at higher altitudes, you won't find the right secondary spring that'll work.
Old Aug 5, 2007 | 07:35 PM
67mustang302
My 570cfm runs the black spring(stiffest) from sea leve-4,000ft without problem. But it's also a setup using a small carb+good air pump for an engine, so it has good venturi signal. It helps on mileage too, espeically the way I drive
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
