non ford auto problem help me if you can
Old Aug 8, 2007 | 04:09 PM
junknotch's Avatar
junknotch
Default non ford auto problem help me if you can
I know this is a non ford issue but hope someone can help out a fellow stang owner.
Last Thursday the car ran fine. i shut it off had lunch got back in it and it started missing real bad, with a flashing check engine light. I took it to a local shop to have scanned and they told me the number 2 fuel injector was bad. I brought the car home replace the fuel injector along with a new pcv valve and plugs. The car ran worse. I tore it apart again and switched out the fuel injector and replaced the number 4 injector. The car still missed but got a solid check engine light. I took it to another shop and was told the car has spark and compression they flushed the injectors and they all work properly. They said the number 2 cyl. had a flat spot on the cam and the valve is bad also. He does not now for sure but assumes that is the problem. When I drove the car home from him the car does run 80% better than it did. I don't think this is true on a car with 55,000 miles on it and is well maintained. So any advice would be great I am thinking a vacuum leak or maybe a coil pack ?
Old Aug 8, 2007 | 05:36 PM
Panther_Driver's Avatar
Panther_Driver
Default RE: non ford auto problem help me if you can
What kind of car is it? Maybe whatever it is has a known bug or issue that someone can chime in on.
Old Aug 8, 2007 | 07:36 PM
junknotch's Avatar
junknotch
that would help sorry about that 2003 impala with a 3.4
Cannibal_carnies
Mar 2, 2023 06:17 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Jskeezy84
Sep 8, 2015 01:40 AM
Stilz
Aug 18, 2015 09:40 AM
