Fuel Pump Help
Old Aug 12, 2007 | 08:52 PM
ncplaya88's Avatar
ncplaya88
Default Fuel Pump Help
I was driving my car and it died not even a mile from my house. I could not hear the fuel pump turn on anymore when I came to a stop. I was trying to figure out the problem before dropping the tank. Its a 1992 mustang gt 5.0. . . . . I put the voltage I measured on the wiring diagram. I am guessing the relay is the problem but I put another relay in its place but still the same problem, Maybe I need to go to ford for the factory relay? The relay I am checking is under the maf attached to the fender on the passenger side. Any other suggestions??? Only six volts at the inertia switch and 6 coming out of the relay to the inertia switch but 12 going into the relay????
[IMG]local://upfiles/53284/0E8968E2624049DB9CCAA257662D4893.jpg[/IMG]
Old Aug 13, 2007 | 01:25 PM
Chopper's Avatar
Chopper
Default RE: Fuel Pump Help
I couldn't open the file but sometimes you can beat on the underside of the gas tank and get the pump to work for a few miles.This only helps when the pump has worn brushes in the motor.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
