'93 conv rear power window question
Old Aug 15, 2007 | 06:52 AM
Jax2A's Avatar
Jax2A
Default '93 conv rear power window question
Need help with my passenger side rear power window. Won't go up and down easily. Replaced the guide bushing in the bottom of the window bracket and greased everything. Someone's been in here before me so there's been damage or someone screwed it up replacing a broken glass. (I found a piece of broken window inside the panels). Whoever did the work did some pretty cheesey stuff so I'm betting they didn't put something back rightt.
So here's my first question, in the bracket that rides up and down the guide post is there supposed to be a guide bushing in the top and bottom sides? When I went looking for the part everything I read said one per side. I'm wondering if the PO put the bushing in the top when it should have gone in the bottom. Any ideas? Thanks,
Old Aug 15, 2007 | 09:08 AM
TwotoneVert's Avatar
TwotoneVert
Default RE: '93 conv rear power window question
Not sure on the bushings. Does the window bind? Can you hear the motor, and is it clicking? The gears in the window motors are plastic and strip easily, I have already replaced my motors once. You can rebuild the gears for less than 10 bucks, but I can find who has the link to the parts. Check out the Convertible sub forum under General Tech.
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Tyoung68
Aug 25, 2015 04:31 AM
