Just blew my motor!!!!
Old Aug 17, 2007 | 12:22 AM
  #21
adamtucker's Avatar
adamtucker
Default RE: Just blew my motor!!!!
well, they from a ticking to a violent rattle. I think there is a broken valve(s). Either way, it doesnt sound right and the motor starts, then cuts out.
Old Aug 17, 2007 | 06:53 AM
  #22
MikeVa's Avatar
MikeVa
Man that sucks. I could have put money on the alternator. I have no idea where that squealing could be from. Usually a rod bearing would be a knock or rap that increases with the rpm's. Could be a bad timing chain or cam gear. If there was that much internal screeching, there would be tell-tale signs in the oil(dipstick). Also that low voltage reading is puzzling.
Does it sound like this?
http://www.n2s1.net/RacingVideos/havoc_enginesound.wmv
Or this?
http://youtube.com/watch?v=n4xnBuhF8Rk
I guess it will need to be disassembled to see what went on.
Sorry man, I hoped it was just the alternator. Let us know what the verdict is.
Mike
Old Aug 17, 2007 | 12:05 PM
  #23
adamtucker's Avatar
adamtucker
yeah, it sounds a lot like the You Tube video.
Old Aug 17, 2007 | 12:12 PM
  #24
adamtucker's Avatar
adamtucker
kinda like the YouTube video, but it was the valves making all the noise.
Old Aug 17, 2007 | 12:23 PM
  #25
MikeVa's Avatar
MikeVa
That sucks. Then it is your rod bearings. Time for a rebuild.
Old Aug 17, 2007 | 02:13 PM
  #26
adamtucker's Avatar
adamtucker
it was rebuilt 10,000 miles ago. How long is a rebuild usually good for?
Old Aug 17, 2007 | 02:26 PM
  #27
MikeVa's Avatar
MikeVa
Wow, if that's the case they messed it up badly. Was it a garage that did this rebuild? Good rebuilds can last 100,000 miles easy. I would take it back and tell them it redo it.
Old Aug 20, 2007 | 06:16 PM
  #28
351W THUNDER's Avatar
351W THUNDER
take off your valve covers and c if theres anything wrong
Old Aug 21, 2007 | 10:50 PM
  #29
1971 Coupe's Avatar
1971 Coupe
The shaft to your oil pump might of snaped. I had that exact problem and seazed up a baring.
Old Aug 27, 2007 | 07:41 PM
  #30
adamtucker's Avatar
adamtucker
I took my car to a performance shop and they found out that my oil pump was "sheared off" . So they are pulling the motor, cause I dont have the facility to do it myself in, and replace it as well as check the main bearings for damage, or anything else that may have been affected.
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
mustangheaven
Sep 29, 2015 11:00 AM
logan409
Sep 26, 2015 07:43 PM
