Girlfriends car
Old Aug 19, 2007 | 06:37 PM
00blackstang's Avatar
00blackstang
Default Girlfriends car
Need ur help guys....... my girlfriend has a 99 mazda 626, its been throwin a cylinder 1 misfire code.. The car studders bad on take off, or on a load... Also shakes wen sitting. I changed the plugs, wires, fuel filter, and coil... What else could it be.. Im going crazy. Please help . thanks
Old Aug 20, 2007 | 11:10 AM
67Sally's Avatar
67Sally
Default RE: Girlfriends car
We had a '99 626 and after about 50,000mi it needed a rebuilt engine. Toss it. No idea what the prob is though sorry.
Old Aug 20, 2007 | 08:13 PM
P.S.I.cho's Avatar
P.S.I.cho
not sure about those motors sounds like a timing belt issue to me and if its shaking like that its a posibility if it has a timing belt it slipped valve met piston breaking/bending components, specially with the misfire code sounds like timing issue to me
Old Aug 20, 2007 | 11:00 PM
00blackstang
i think its a timimg issure to, how much u think i could sell that car for liek it is. with 84,000 mi
Old Aug 21, 2007 | 07:09 AM
Chopper's Avatar
Chopper
Have you checked the injectors? Move the #1 injector to a good cylinder and see if the problem follows.If so,you have the culprit.
You need spark,air AND fuel to get the engine to run.
Old Aug 21, 2007 | 09:44 AM
00blackstang
put brand new injectors in.
Old Aug 22, 2007 | 07:07 PM
00blackstang
ok, so there were brand new motorcraft plugs in there that autozone recommended, and someone on another forum told me the cars only like NGk plugs, so i put them in and the car runs great, i dont get it.
Old Aug 22, 2007 | 07:34 PM
P.S.I.cho's Avatar
P.S.I.cho
that doesnt make sense to me either never heard of a car running off one spark plug and not starting at all on the other, usually theres a performance difference not a complete failure strange maybe you had a bad set of plugs?
Old Aug 22, 2007 | 10:56 PM
00blackstang
i have no idea, but it studdered incredibly on the motorcraft plugs, and runs fine with the ngk
djbigskrilla
Sep 20, 2022 01:04 AM
jink21
Aug 13, 2015 04:33 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
'stangdude
Aug 12, 2015 01:27 PM
