Could a Fuel Pump be to much
Old Feb 5, 2005 | 10:23 PM
DaGGer's Avatar
DaGGer
Default Could a Fuel Pump be to much
ok well i was looking on ebay for a fuel pump because mine makes this really really really loud buzzing sounds and i wanted to know if it to much to buy say a 5.0 fuel pump for my 4 cyliner
Old Feb 6, 2005 | 06:54 AM
HAUS's Avatar
HAUS
Default RE: Could a Fuel Pump be to much
yes im pretty sure they use the same 88lph fuel pumps. but im not sure if you can use a 110, 155, 190 or 255 for the 4 cyl. but dont quote me on it. any one else have their opinions.
Old Feb 6, 2005 | 10:09 AM
DaGGer's Avatar
DaGGer
well its like 30 dollars for a 110 on ebay and like 90 at advanced auto parts...so i would rather buy that one instead
Old Feb 6, 2005 | 10:24 AM
HAUS's Avatar
HAUS
I understand you want to save money but find out first if you can use a 110 lph in a 2.3 L. No sense buying it if its not going to work or is gonna make your car run like ****. 110 might be too much fuel for a 4 cyl. PM roundman. He probally knows for sure.
Old Feb 6, 2005 | 12:39 PM
vfast's Avatar
vfast
I ♥ Acer
the fuel pump for the 4 and 8 are the same..yes you can use a 110 lph pump....a 225 would cause problems in your 4 banger and even in near stock 5.0's....
Old Feb 6, 2005 | 10:24 PM
DaGGer's Avatar
DaGGer
ok thanks
Old Feb 13, 2005 | 11:19 PM
tyybo's Avatar
tyybo
k a question on the fuel pump issue.. IS ther a performance gain if you combo a fuel pump with some injectors, and a MAF&TB upgrade?
Old Feb 14, 2005 | 04:05 AM
91LXstanger's Avatar
91LXstanger
yeah. if u put some AFR's and a street/strip cam with other little goodies, u should upgrade your fuel delivery for the A/F ratio's concern. And with the head and cam upgrade it will benefit greatly with a larger MAF and TB with matching injector sizes along with a larger fuel pump. The fuel injectors and pump dont increase hp, but accomadate to the hp makers. They're nessesary for aggressive part add-ons.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
