something wrong with my clutch
Old Feb 6, 2005 | 02:15 PM
aamilo's Avatar
aamilo
Default RE: something wrong with my clutch
Hey Man I feel for you. I have always had beaters but I have spent more money on my '91 in the last 6 months then EVERY car I have ever had combined. And there is still SH*T going wrong with it. Some cars are just cursed. As for the problem it is Probably one of the clutch cables. I just did both on my car this weekend (didn't fix my problem but that is another story) One goes from the pedal to the clutch fork the other is short and goes from the fork into the bellhousing. Check the short one first is is the least expensive and easiest to replace.
Old Feb 6, 2005 | 06:54 PM
99saleen351r's Avatar
99saleen351r
A broken clutch cable isnt that big of a deal....Unless the clutch self destructed
Old Feb 6, 2005 | 08:19 PM
Dan04COBRA's Avatar
Dan04COBRA
I dunno why you insist on painting that crap wagon man, you won't get any more money for it. Just drop it off at a junkyard or try getting a couple hundred bones for it.
Old Feb 6, 2005 | 10:15 PM
DaGGer's Avatar
DaGGer
well ok i'm selling it...it hates me....but anyways....i'm going to check the cable...then if i fix it...i'm going to put it up for sale...so how hard is it to change the cable for the clutch under the dash...
Old Feb 6, 2005 | 10:25 PM
ZachW04Stang's Avatar
ZachW04Stang
It may not be the clutch cable, although that would be the first thing I would check. It could be that the throw out bearing (release bearing), not sure what ford calls it. Are you able to pull the clutch pedal up by hand or does the pedal seem to be jammed at the floor? Does it take force to pull the pedal up?
Old Feb 7, 2005 | 12:44 AM
aamilo's Avatar
aamilo
I would start with the cable that runs into the bellhousing, it is really simple and cheap. The one under the dash is not difficult just awkward because there really isn't much room under there. IF you are lucky the cable will be broken and you can tell which one needs to be replaced but more often then not they are stretched so they look fine but they need replacement. The secret to changing either one is to disengage the selfadjuster. This will take the tension off the cable enough to remove it from either end. Let me know if you get stuck or need some help, like I said I just did both yesterday.
Old Feb 7, 2005 | 01:16 AM
DaGGer's Avatar
DaGGer
well the thing is...something snapped...i was pressing the pedal down and then bomb just went right to the floor..it could have just stretched that far...but i will look around at the cables...and right now i'm going to look at the one under the dash because it muddy and i don't want to lye in it...
Old Feb 7, 2005 | 01:16 PM
aamilo's Avatar
aamilo
Yea you wouldn't think they would stretch that far but on my sisters '89 the small cable stretched about 1/4 inch and that was enough to have her pedal resting on the ground. I mean it could be a lot of other things but this isn't the first time I needed to replace those cables on a fox stang.
Old Feb 7, 2005 | 01:38 PM
DIVER8374's Avatar
DIVER8374
yeah i would fix it just enought so it runs and then get rid of it, cut your losses with the 4 banger, i had a 86 4 banger a long time agao and it was the biggest pile of crap ever, get rid of the 4 and move into the 8. If you can i would look for smething a little newer than 86 if you can, try and find a early 90's, sorry for your luck man hope thing work out better in the future, just dont give up you will find a good one if you look around for it,
Old Feb 7, 2005 | 04:48 PM
DaGGer's Avatar
DaGGer
ok well the clutch...it just floats around like there isn't anything attachted to it...you can push it down and it comes back up but i think its the cable...this may have been from when i was stuck on the edge of an emanckment because i went off the road...but it still doens't matter...i'm selling it...i don't know if i am going to get the 86(a newer one if i can find it) or this 93 mazda mx-6...its a 5 speed 6 cylinder...now the mustang is making me really want it but its too old really...its got a nice engine and everything...but i would want the styler that i have...maybe i can try to get this one next to my g/f house..its a convert but hey it would be nice to have one of those...
Thunderball
15
Nov 22, 2015 11:49 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
marc954
Sep 29, 2015 11:18 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
