CAMS 4 A 99 GT
Old Feb 6, 2005 | 01:31 AM
droc949's Avatar
droc949
Default CAMS 4 A 99 GT
I WANT TO BUY VT STAGE 1 CAMS FOR MY 99 GT MUSTANG. IS THERE A WEBSITE WHERE I CAN BUY SOME GOOD CAMS? ALSO WHAT GEARS SHOULD I GET WITH MY CAMS? 3:27 OR 3:55 GEARS. KEEP IN MIND I DRIVE MY CAR EVERY DAY!
THNX GUYS!
Old Feb 6, 2005 | 01:43 AM
ZW99GT's Avatar
ZW99GT
Default RE: CAMS 4 A 99 GT
First of all, welcome to the forums. I have a 99 mustang gt and i wondered that some thing when i got my car. Just go pick up a 5.0 mustang magazine(dont let the name fool you, its got tons of 4.6l stuff in there) there are at least 5 ads with cams in there. Im guessing you meaning rear end gears? Chances are, you have the 3.27 gear in your car. At least go with the 3.73's if not the 4.10's. 3.55 would be a waste of money. I drive my car everyday, and i cant tell a bit of difference in gas milage(driving conservitively). Good luck with the cams. save up your money, and get your heads ported and polished while you've got everything apart.
Old Feb 6, 2005 | 02:00 AM
jacrockett's Avatar
jacrockett
I like my Crowers... but you have to have the heads done to run smooth.
3.73 gears on the GT work well
Old Feb 6, 2005 | 02:28 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: droc949
THNX GUYS!
I beileve the website for VT is http://www.vtengines.com/
Two things about cam install.
1. I do not recommend it for a novice, or even a shadetree type. At least have a pro on hand to help out.
2. DO HEADWORK with the cams. I am seriously considering the stage 2s from patriot performance. The difference is having a 290 ish RWHP car and a 310+ RWHP car.
Old Feb 6, 2005 | 02:34 AM
jacrockett's Avatar
jacrockett
High lift cams with lits of overlap are great if you have a power adder... aka blower.
Make sure you get good springs too.
Old Feb 6, 2005 | 02:30 PM
droc949's Avatar
droc949
BUT STAGE TWO ISNT FOR THE EVERY DAY DRIVER RIGHT? AND IF I DO GET THE CAMS I WILL GET IT DONE PROFESSIONALLY. AND I WILL GET THE 3:73 GEARS PUT IN TOO!
Old Feb 6, 2005 | 04:27 PM
ZW99GT's Avatar
ZW99GT
Thats awesome, I hope you got some big bucks for the parts plus install.
Old Feb 6, 2005 | 09:24 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: droc949
There is little if any difference in the everyday drivablity of stage 2 vs stage 1. My car is 100 percent steetable, even with this crap tune i Have.
Old Feb 6, 2005 | 09:42 PM
jacrockett's Avatar
jacrockett
I drive my GT everyday. Set it up right and u can too. Do the heads
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
