steeda timing adjuster install
Old Feb 6, 2005 | 08:31 PM
UT04GT's Avatar
UT04GT
Default steeda timing adjuster install
Ok, my timing adjuster finally arrived and I went to put it on today but I got all scurred because it required changing the crank bolt. I don't have the tools to set the factory torque/pressure on the bolt and I was worried that it would seriously mess things over if I didn't return it to factory specs. For people who have installed it, did you have a torque guide when you put it back on or what? Thanks
Old Feb 6, 2005 | 10:37 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: steeda timing adjuster install
You definatly have to torque it to the correct specs. You can probably find a decent torque wrench for $50. I wouldn't trust the really cheap ones, I found out the hard way.
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Dec 17, 2016 03:30 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
ponyride00
Aug 12, 2015 01:57 PM
