Ford 9 inch
Old Aug 26, 2007 | 09:50 PM
79bronco's Avatar
79bronco
Default Ford 9 inch
In my ford 9 inch i f***ed somthing up...
When i put it in gear all i hear is grinding...and dont go any were...
Theres fluid coming out of the end of the axle tube on the driver side...
any ideas of whats wrong?
Old Aug 27, 2007 | 12:29 AM
ktm300's Avatar
ktm300
Default RE: Ford 9 inch
I grenaded a rear end myself onetime, but I was going about 40mph and all of a sudden the back end locked up and started bouncing all over the road. Quite an experience! But your best be is to open it up and see whats broken, and then replace everything while you're in there, bearing, seals etc
Old Aug 27, 2007 | 12:31 PM
Projectquick's Avatar
Projectquick
If fluid is coming out of the axle tube you have a problem. I delt with 9" rears when I had my bronco. You have to take the third member out and check the fluid. If there is metal shavings in there you have a major problem and all the seals should be redone in the axle. Until you crack it open I can't really help more with out knowing what exactly went wrong.
Old Aug 27, 2007 | 12:38 PM
SoDakStang's Avatar
SoDakStang
ORIGINAL: Projectquick
+1. If there is fluid leaking, then you have a seal problem anyway. If it is grinding, 90% chance you have a bearing out. Which one? Who knows. Pull it apart and find out. No other way. Make sure you look over every tooth on the ring and pinion to make sure the bearing didn't take out those two.
Old Aug 27, 2007 | 01:57 PM
79bronco's Avatar
79bronco
A bearing could cause that much damage? I figured if it was a bearing it would still move...it might make more noise but i thought it would still move...?
Im going out to rip it apart soon...but i figured i should clean all of the mud off first so im not droppin s**t into the housing...
drfister
May 3, 2018 10:38 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
vincep99
Aug 30, 2015 11:42 AM
my96mustang
Aug 24, 2015 06:12 AM
