Sputtering Problem
Old Feb 17, 2005 | 01:38 AM
2000GRNMachine's Avatar
2000GRNMachine
Default RE: Sputtering Problem
well, he said that he does not have "wires" just coils.
so does he have ignition wires or not ?? i do not know
Old Feb 23, 2005 | 11:01 PM
2000GRNMachine
no new info huh guys ??
Old Feb 23, 2005 | 11:28 PM
vfast's Avatar
vfast
I ♥ Acer
and injector could be bad....
Old Feb 24, 2005 | 10:07 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Hey im back. I forgot about this post. lol. Yeah check for coolant leaking. Also there are no plug wires. Only a coil pack and a plug.,.... Well i mean there are 2 wires that go to the connecter, but just for v-ref. Also, Vfast, could be right also. Could be a bad injector, or a leaking injector. The world may never know.
Old Feb 24, 2005 | 10:25 PM
devinsteen's Avatar
devinsteen
ORIGINAL: vfast
I'm going with vfast on this one. I just checked my injectors and they were fvcking dirty. I was also having a sputtering issue that got progressively worse. Have the injectors thouroughly cleaned I see how it runs.
Old Feb 25, 2005 | 03:25 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Warning on the fuel injector cleaner...i used it onece on a 88 olds and 5 out of 6 F.I. went...unusual. Check engine deals with exhaust.
Old Mar 8, 2005 | 07:45 PM
xbattlevandriver's Avatar
xbattlevandriver
I have a different sputtering problem that may or may not be related. My vehicle is a 95 mustang gt
My car Idles fine and works well at WOT but sputters badly in between Idle and WOT. So basically it starts up fine and idles fine but shortly after starting to drive it will sputter as if it is getting no fuel and basically not accelerate at all unless the gas pedal is depressed all the way (WOT). I just put new gears in the car. Was 3.08 now its 3.73. Also I have the wrong gear in the tranny for the spedometer because the one that came with my gears was wrong. it was the 7 tooth gear instead of the 8 tooth. I doubt this has anything to do with it but. . .?
I have CAI, Full MSD Ignition, Billet Adjustable fuel pressure regulator, Full exhaust.
My car had done this before. Just like sputter once or twice, but then it would go away. Now it does it all the time. Any ideas?
Thanks
Old Mar 8, 2005 | 07:46 PM
xbattlevandriver
Forgot to mention I have no engine code either
Old Mar 9, 2005 | 12:53 AM
2kstang's Avatar
2kstang
I ♥ Acer
I was havin same prob on the v6 it happend to be a cracked manifold in 2 spots....and its only 50k miles on it. So i got me some long tube headers[sm=groupwave.gif]
Old Mar 10, 2005 | 04:01 PM
2k5pony's Avatar
2k5pony
Check your ignition timing.
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
