a question for SERIOUS ENGINE BUILDERS
Old Sep 1, 2007 | 07:10 PM
my77stang's Avatar
my77stang
Default a question for SERIOUS ENGINE BUILDERS
looking for input on variable lifters for my 289 build.
has anyone used rhoades lifters? how about the crane "fast bleed" or hi intensity as they are now known as
im trying to figure out if
a) they really work good enough to warrant the cost of buying
b) if one is better than the other
btw, they make these in rollers too (at least rhoads does) so you EFI guys may have just stumbled upon some go-fast goodness
Old Sep 2, 2007 | 12:07 PM
tinman's Avatar
tinman
Default RE: a question for SERIOUS ENGINE BUILDERS
Both of those things are really the same.
Using either one would sort of depend on the cam you want to use.
They were originally for NHRA stock elimintor where peeps use real long duration hydraulic cams that are stock lift.........
Old Sep 2, 2007 | 02:57 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I'm using the Comp lifters on my car. They do make a difference, but mainly because stock-style lifters can't really handle high lift without problems with sticking.
Old Sep 2, 2007 | 04:14 PM
my77stang's Avatar
my77stang
the comp "fast bleed/hi intensity" lifters? not just the regular comp lifters? how's the ticking? i hear they are supposed to be noisey
drumhedd2005
Aug 13, 2015 09:59 AM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
