2002 mustang, stuck window
Old Sep 8, 2007 | 01:38 PM
motorhead6776's Avatar
motorhead6776
Default 2002 mustang, stuck window
ok so the driver side window in my 2002 mustang wont go up.the passenger window works fine. if i push the button up the motor dosent do anything if i push it down it clicks. the click is louder than the passenger window if you try to put it down once it is already down. what could be wrong and how do i fix it?
Old Sep 8, 2007 | 08:42 PM
scarslilpyro's Avatar
scarslilpyro
Default RE: 2002 mustang, stuck window
Sounds like the motor, or parts of the window motor assembly need to be replaced.
If you want to try something daring, you can take the door apart and try to see what could be causing it.
It's also a better idea to do this and replace all the parts yourself, because it will save a lot of money.
Just get a manual so you know how to get the door panel off and where all the parts go, etc.
Old Sep 8, 2007 | 11:29 PM
945LSTANG's Avatar
945LSTANG
what do you mean by "it clicks"??
Old Sep 9, 2007 | 02:59 PM
Murdoc's Avatar
Murdoc
I ♥ Acer
its the regulator. theyre cheap, do the install yourself, its fairly easy.
Old Sep 21, 2007 | 02:27 PM
VABEACHPONYGURL's Avatar
VABEACHPONYGURL
Same problem.. but I can't get the tracks and everything back where it was... they wont move.. go figure.. and I don't have a manual
Old Sep 21, 2007 | 11:34 PM
scarslilpyro
ORIGINAL: VABEACHPONYGURL
A manual costs about, what, $20? It's probably the best money can buy in terms of your cars life.
If you can't afford it, sell your car and get some crappy civic.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
daytooday
Aug 11, 2015 09:22 AM
Danwiel
Aug 11, 2015 06:49 AM
